Interesting Electronic Ignition conversion ATTN Bruce(VA)
HCooke
Hey Bruce and others, check out this EI
conversion for N tractors on another forum!
Here
I love it! Probably a lot more stable than the Pertronix units. I know the purists will have a cow, but looked like a fun project, not trying to solve a non-existing problem in order to sell parts. Coupling that to a Megasquirt (open source fuel injection controller) and having digital governor control would just be icing on the unnecessarily overly complicated cake.
The transistor radio I built in Electronic school back in the 80's had 3x more components that that setup.
Goes to show you what a (bucket) correction cup full of parts can do for you...and 50 spare hours. :shock:
That is an interesting method.I'm sure it's a one of a kind conversion. I'll stick with my points for now. Should go change them. Been in the old 9n for 14 years now.
Beam me up Scottie--TOH has met his match with that kind of project if he ever posts here. <'(((((><
And here I thought a good idea for easy ei was to run points low current to trigger simple transistor ckt controlling coil
