Fuddy Duddy
Bought a green house from my Neighbor the Preacher, 94' X 20'. Actually belonged to his Church. They planned to feed the hungry. Put it in his yard. Every one was to pitch in with the work. I'm sure he had some good help for starters. But he said lots more showed up for the Harvest then the rest of the work. Hearts were in the right place. But he was left with too much of the work to do on his own.
So they gave up the idea and now it's mine.
Took most of it down the first day. Came back the next for the rebar and boards along the ground. I had already removed most of the ends before I took a picture of it while still standing. Came with a really nice exhaust fan.
The 8N played it's part in the end pull the 5' #6 rebar out of the ground. Each were drove in about three foot. Looking in my scrap pile I found and old metal gusset left over from a metal building I had built long ago. Didn't even have to drill a hole or anything. It worked as it was. If you look, you see I had in the pass cut off some of the metal for use on another project. Didn't take my phone with me while doing the job. So the pictures were taken once I got back home. (Simulated) Some of them took some hard pulling. Others can right on out. Wife came down to help with the rebar. She would place the metal over the rebar then remove it. That was a big help. Other wise it would had been a lots of climbing off the Jungle Jim set up. I'm well pleased at how well the loader helped out. While Ns might not make the best loader tractors, mine has saved me a lots of work. Probably could had done the same thing with the 3 pt. But I think the loader worked better than it would had.
O'Yea, the OT: 70 plus degrees today. The little scooter was waiting for me to finish the pictures. Second project for the day was to take Harley out for a work out
