Ford Jubilee wiring harness problems
Bevan
I bought an aftermarket harness for my Jubilee and it seems the wires are not long enough for the starter solenoid and barely long enough for the distributor cap. Beyond that I am totally confused about the wiring set up on the block near the regulator. Anyone have any good tips? Pictures?
Can our Forum Has stickies at the top? If so, I vote we have several topics that have some basic info that is asked over and over. 1, wiring diagrams, 2, Bruce's 75 tips, 3. paint stuff, etc...
JEff
For the regulator, ohm the wires out to see what is what, then matchup like on Genny to reg.
Field to field
Arm to arm,
I believe I have figured out where I got lost. The terminal block is more than two terminals. I don't know if its a aftermarket item the previous owner put on or a limited item offered on this tractor. I will post pictures if I can't resolve the issue.
