8N spark plug wire tube
GunnyIa
Looking for subject item, for early 8N. That would be a 3-hole tube (I think), looks like the top tube shown here. Picture would be appreciated.
Forgot to mention, picture courtesy of Rod (Wild child) on an earlier post.
Thanks in advance, for any and all feedbacks!
Gunny, in Iowa
My early 8N (12/47 mfg) has the tube at the bottom with four holes.
The actual wiring skips the second hole from the front. No. 4
comes out the rear of the tube, next is no. three, then no. 2 then
skip the second hole and the front most hole is for cyl. no 1.
This can be clearly seen in the 1949 parts book where the entire
engine is shown. putting all the wires through the four side ports
results in 3 and 4 being long out of the tube.
Sgt I guess I will try your post has set long
enough with no reply so I cant be the only one
that? Are you looking for one? One is for front
mount dist and 1 is side mount dist I would
say.Early 8N would be the f/m on bottom. Check
here at yt if not try ebay.
(quoted from post at 03:56:22 01/27/15) My early 8N (12/47 mfg) has the tube at the bottom with four holes.
My early 8N serial number 949 came with a 4 hole tube.
I believe I thought wrong! I should be looking for a 4-hole tube. Thanks for feedback that cleared up my mystery!
Yes, I AM looking for a tube, for my 1947 8N f/m. Didn't find one on this site, at least just the tube without new wiring. My wiring appears to be fairly new. I'll keep looking.
Gunny, in Iowa
