I've been refurbishing a '49 8N with front mount distributor. It is 6v with generator. The old wires were missing a lot of insulation but the tractor would crank and run fine.
After replacing with a new wiring harness from Dennis Carpenter and new spark plug wires with little to no slack, it looks great but won't start. Obviously, something with the new wiring is the problem.
I got no spark at all until i ran a hot wire from my on/off switch down to the coil. I've confirmed there is a spark and compression on all four cylinders. I don't have a compression gauge but i put my finger over the sparkplug hole and felt it blow and suck back in.
Now, that i have spark, i can make the thing backfire like nobody's business but can't manage to get it running.
My spark plug wires are in the correct firing order, but they are rotated 90 degrees from the numbers on the distributor cap. The rotation is due to the new spark plug wires. Because they are almost too short, i can't test them in another configuration. Is the 90 degree rotation a problem or does it only matter that i've got the firing order correct?
For the sake of troubleshooting, i'm assuming that the voltage regulator has to do with the generator recharging the battery and won't impact the starting process at all. Please let me know if i'm wrong.
I did clean my spark plugs which were pretty nasty and also the contacts in the distributor cap. But i haven't monkeyed around inside the distributor yet. Hopefully i don't need to since that was all working before i replaced the wires.
I appreciate any advice you can provide. I do feel a little silly asking about this though because there are so many other posts here about "no spark" and "can't start". They all seem just a little bit different than what i've described here.
Regards,
Dan
Regards,
Dan
