8N top link rocker
Sean (TX)
Anyone have a good pic of the rocker with the top link connected. I know it is different then a 9N. Never hooked one up thou. Trying to figure out why someone claims he has to grind down the top link in order for the pin to line up. Pulling my hair out on this one.
Is this the picture you wanted?
The after market top links are too thick on the end and will hit on the draft control yoke if you don't grind some off the end of the top link.
Mark
He may be trying to hook up an aftermarket top link that won't fit.
I have one out here that someone has ground down to get it to clear.
(quoted from post at 19:30:02 01/20/15) The after market top links are too thick on the end and will hit on the draft control yoke if you don't grind some off the end of the top link.
Mark
Thanks guy's! They fit perfect on a 9N. He bought it at TSC. learned something new today.
