Paul.......you do know the WIDER the sparkie gap, the MORE kilovolts it takes to jump the gap, don't you? The weird 4-nipple front mount dizzy really doesn't have many kilovolts to spare. Keep yer sparkie gap at 0.025". 70psi compression on a DRY test ain't braggin' rights. Ford specs: 90psi MIN, most good runnin' N's test about 110psi. Brand NEW overhauled N-Engines test about 125psi.
1-cylinder low compression will cause VIBRATION. Sometimes in COLD weather, you need to warm the carb. Try wrappin' some aluminum foil around carbie and exhaust manifold. (be creative) .......the COLD Dell
