I was plowing my fields last spring and kept having overheating and rough running problems.
I was checking plugs,wires etc. I had spark to all four cylinders. So I began running motor and pulling one wire at a time to see if the motor sounded any different. When I pulled 4,3 and 2 the motor changed drastically. When I pulled number one I had no change at all. So I figured I might have a valve problem. I don't know what the next move should be. I would appreciate any help I can get....(as for the overheating.. The radiator is original and I can see it has been repaired. I'm thinking I should change it out) Thanks Ron
