8n ford hydraulic system
Sclem
HI: Lift lever in normal position will not move lift arms. I took back bolt out & tilted lever forward to rotate control shaft more counterclock wise to get lift arms to move. Where do I start to correct problem? Thank you for any information.
" Lift lever in normal position "
Would that be the draft control lever under the seat or the touch control lever to the right of the seat?
75 Tips
Without my decoder ring or xray glasses, I'm gonna guess you have jimmied thequadrand and lift handle to get more rotation on the lift control.
If so, then your can pin is likely worn and or the linkages out of adjustment. Moving the quadrant back likely could help, but the real fix is pulling the lift cover for a look see, then correct issues as found.
Post back with better / more info, for better/ more advice.
