Hello,
I have an 8n that seems to run pretty good. It had set for a couple of years before i acquired the tractor. It doesn't smoke out the exhaust and holds 40 lbs oil pressure at working speed and 20 at hot idle. The tractor seems to have decent power, but I don't have any experience with them.
However, it does have a white vapor-like smoke coming out of the crankcase vent when it is running. It doesn't puff out, it just seems to be rising out of the vent when the cap is off. It is not very much smoke at all, but it is there.
I changed the oil on it yesterday and cleaned quite a bit of what seemed like clear water off of the tab that keeps the oil from splashing out. Ran it for about an hour after the oil change and the clear water was back as much as before.
Is this condensation in the crankcase? I was thinking this could be causing the smoke, but the smoke quits as soon as you kill the engine so that leads me to believe it is blowby.
What do you guys think? If it is blowby and it is slight does it have much life left in it? I have no idea how long they generally run once they start this before you absolutely have to rebuild them. I had planned on finish mowing 50-100 hours a year with this tractor.
Thanks.
Thanks.
