trouble installing rotor with spring
pixer
recieved spring that holds rotor on distributor shaft manual shows it going on with tab going in down direction, it fits over the shaft nicely but i cant then get the new rotor to go on over the spring, does the spring part squeeze together and go up in rotor first then down over shaft? how do you install any tricks to putting it on, i assume all rotors are made to accomodate this little irrritable thing.
