8N INDUSTRIAL MOTOR
wilber
I have a ford industrial motor on a 8n .it is type 4-28 serial number 3668-c25cs. is there any difference in this motor than a 8n motor and is this a sleeved motor. thank you WILBER
I have the same motor in my 48 8N-cant answer your question,but if anyone does I would like to know.THNX
wilber.......most industrial motors used a magneto 'cus there was NO battery. Also used "armstrong" starter ...ie... hand crank 'cuz there was NO battery fer starter motor. Obviously, since yer engine is already in an 8N tractor, these issues have been addressed and solved.
As fer sleeves, you won't know until you look up its skirts. (naughty boy) ...ie... Ya haffta take yer oilpan OFF. There are NO external indications that I know of. .......HTH, Dell
(quoted from post at 06:36:30 12/21/14) I have a ford industrial motor on a 8n .it is type 4-28 serial number 3668-c25cs. is there any difference in this motor than a 8n motor and is this a sleeved motor. thank you WILBER
The industrial engine that someone put in my 52 8n had the thin sleeves in it and has a magneto. It has a starter,and generator also. the block is the same as a late 8n side mounts but has a front cover of a front mount dist to drive the magneto.
Do you have a fuel pump opening ? I have a few cams that have fuel pump lobes but I have never seen a block with a fuel pump hole , just a flat spot .
I LOOKED TO DAY IT DOES NOT HAVE A OPENING FOR A FUEL PUMP. THE TYPE NUMBER AND THE SERIAL NUMBER ARE ON A TAG ON THE BELL HOUSING ON MOTOR SIDE.I WOULD LIKE TO THANK EVERY ONE FOR THE REPLIES
Here's the tag off mine. I don't remember for sure but I think it had sleeves, dome pistons. It had a front mounted magneto, no fuel pump access hole, also had a belt pulley on the flywheel with no clutch to engage or disengage. When the engine ran so did the pulley.
Kirk
