(quoted from post at 15:43:05 12/17/14) Tinned is a term used that tell me it has had solder applied to the end of the wire. Use it a lot when I was still a Navy E.T.
(quoted from post at 15:46:24 12/17/14) As in coated to prevent corrosion.
Here's a good read, not a tech article, but one I coil scare up to help u understand
tinned wire
(quoted from post at 18:12:10 12/17/14) Caryc........whatcha gonna doo with 100ft of sparkie wire??? NAPA sells sets of 4-cylinder COPPER core sparkie wire. ($10, cheap) When I re-sparkled my eazy starting 52-8N, the original sparkie wire was STIFF as brake tubing and the blue sparkies danced all over the outside of the wires.
I bought copper core HOT-ROD sparkie wire fer Chebby V-8 'cuz they had built-in right-angle booties to fit under the gas tank. (now I gotta spare set of sparkie wires, eh?) The NEW copper core sparkie wires are limp as wet noodle and no blue sparkies dancin' outside.
You do know why we specify copper core 'stedda modern string sparkie wire, don't you? The string is actually a CARBON RESISTOR to suppress IGNITION NOISE that drives modern engine computer control NUTZ. Besides that, modern sparkie volts are about 2-times HOTTER yer N-Sparkies.
You should be happy yer not changin' sparkie wires on WW-2 B-17 Bombers where the sparkie wire was INSIDE woven braid ground shields.
Do as we ADVISE, don't fight it....... respectfully, yer sparkie-meister Dell
(quoted from post at 19:05:04 12/17/14) Caryc,You can get your copper sparkies right here at this site.
plug wires,wires
(quoted from post at 19:32:07 12/17/14) You don;t read well do you.
Description: Universal Spark Plug Wire Set, 4 Cylinder, 90 degree boot,CUT TO LENGTH. Longest Reach is 33 inches. Solid brass distributor coils, Zinc-coated plug terminals, tin-coated copper core, boots constructed from EPDM rubber and dual-jacket insulation. Meets SAE J2031 Specifications. Made in the USA.
Spark Plug Wire Set, Universal, 4 Cyl. Part Number CPN12259
........and if someday Santa brings a Pertronix Ignitor II to your tractor, then all that wire will be scrap. Not this Christmas though.(quoted from post at 10:18:39 12/18/14) That Napa wire is likely tinned copper, doubt its aluminum, but in any case, aluminum, copper, even iron core will conduct fine, Save your money on the roll. Tsc used to carry precut metal core wire too but I have not looked in a while
