spring clip to keep rotor in place
pixer
i recently posted about missing rotor, my bad ,i was looking at bottom of the dust cover that was stuck to distribtor cap, when i got dust cover out of cap there was the rotor but i didnt see the spring clip to hold rotor on, when you buy a points replacement kit do you get this spring clip in the kit?. also it seems i cannot leave the dust cover out because the cap wont secure wnd is loose without dust cover.
" when you buy a points replacement kit do you get this spring clip in the kit?"
Nope.
" also it seems i cannot leave the dust cover out because the cap wont secure wnd is loose without dust cover."
The dust cover was added for a reason.
But if you insist on not using it, then you will need a new cap.
And, if the cap has carbon tracks or the brass t1ts are burned, you will need a new cap anyway.
75 Tips
(quoted from post at 06:12:32 12/17/14) i recently posted about missing rotor, my bad ,i was looking at bottom of the dust cover that was stuck to distribtor cap, when i got dust cover out of cap there was the rotor but i didnt see the spring clip to hold rotor on, when you buy a points replacement kit do you get this spring clip in the kit?. also it seems i cannot leave the dust cover out because the cap wont secure wnd is loose without dust cover.
this site has the clip!
-8N_Rotor-Clip_8N12213
Until you get that spend clip in the mail, put a couple small pieces of masking tape on the top and sides of the shaft and out rotor on, it will work till the clip shows...
(quoted from post at 11:53:08 12/17/14) Because he said the cap won't stay in
place with out the dust cover.
I will have to check mine, but I thought i used it some without the dust cover. I only see one cap available. the side clips may be the issue, i think in his original post he said one was missing?
