Snow plow for Wagner FEL?
stimpy451
Has anyone fabbed up a snowplow to take the place of the bucket on a Wagner or similar FEL? I keep staring at it wondering how well it would work.
Still waiting for the snow here in Central MI. It was 55F yesterday and I rode my motorbike to work....
You see them here fairly often on tractors, skid steers, etc but usually they just push straight.
Keep in mind if you angle it, the farther out front of the tractor the blade is mounted the greater it will push your tires sideways.
I built one years ago to fit on the bucket of my loader. It is 8.5 feet wide and is a V plow that way it does not push the from end side ways
Old, thanks for that - now I understand more about why they made a V-plow. Never thought about it that much before.
(quoted from post at 10:16:17 12/16/14) Has anyone fabbed up a snowplow to take the place of the bucket on a Wagner or similar FEL? I keep staring at it wondering how well it would work.
Mine works great.
BD
Is that tractor hard to steer with that plow on the front? I know my NAA with the Superior loader is hard to steer with the pie weights and rear blade. That blade looks heavier than my loader bucket.
(quoted from post at 22:38:58 12/21/14) Is that tractor hard to steer with that plow on the front? I know my NAA with the Superior loader is hard to steer with the pie weights and rear blade. That blade looks heavier than my loader bucket.
I have add on power steering. Only reason I bought this one. The fluid is in the silver reservoir. There is a drag link across the bottom.
Don't know how much weight the chains are. I just threw them on. Probably 250-300 lbs. I have inside wheel weights as well.
BD
