Trucker1290
My 2N with a six volt electrical system will
not start with the 6 volt battery. Battery is
good, took it to NAPA and had it tested.
putting out 6.8 volts and 685 cca. When I try
to start the tractor it will turn over but will
not start. If I jump the starter with a 12
volt booster, she fires right up almost
instantly. Use to start up every time until
recently. It's only in the high 20's to low
30's so temperature should not be the issue.
Any suggestions where to look now?
Thanks in advance
Thanks in advance
