Copper points to condenser strap--front mount distributor
racerjim0
Is the short thin copper strap that goes from the
points to the condensers screw insulator terminal
available to purchase separately?
Anyone have a part number?
I could probably also use the plastic insulator and
screw if it comes in a kit
(quoted from post at 12:27:24 12/08/14) Is the short thin copper strap that goes from the
I was not able to ever find it listed, I used a piece of copper from an old set of points to change mine and the one in there was basically torn in half
" Is the short thin copper strap that goes from the points to the condensers screw insulator terminal available to purchase separately?"
No
You need to make your own. Use the copper strip from an old set of points.
" I could probably also use the plastic insulator and screw if it comes in a kit"
Go to Home Depot & get Hillman p/n 881189 & make your own insulator.
The Hillman Group
Model # 881189
Internet # 202242466
0.250 x 3/8 SQ Nylon Anchor Nut
You won't find a concave head brass screw even if you buy a new plate. Best stick w/ what you have.
75 Tips
For the front distributor?
The MPC (page 149) doesn't show it as a separate part because it attached to the plate. And I can't find it in Carpenter's catalog.
75 Tips
You can use the copper strip from old set of points. The plastic insulator can be made from a plastic license plate insert that snaps in your bumper for your license plate bolts to screw into. They are available at auto parts stores!
