My 9N oil filter canister cap is held in place by a bolt that extends thru the spring under the cap and threads into a rod in the filter core and gasket. My shop manual instead shows a long bolt extending all the way thru the filter. My problem is removing the rod or the filter without damaging something, such as the canister?
Also, there is an open hole to the rear of the oil pan, thru which is visible the flywheel teeth. What kind of plug originally was in the hole?
Thanks,
Lou
Thanks,
Lou
