break pedal adjustment
pixer
my 8n break pedals are not even, rt.pedal lower than left pedal, when i change shoes is there any adjusment for this inside drum or after shoes are adjusted using star wheel do you have to go to the toothed connection where pedal rod attaches to rod that goes inside drum? right now the oil soaked brake shoes look to be the same thickness.
(quoted from post at 17:50:38 12/03/14) my 8n break pedals are not even, rt.pedal lower than left pedal, when i change shoes is there any adjusment for this inside drum or after shoes are adjusted using star wheel do you have to go to the toothed connection where pedal rod attaches to rod that goes inside drum? right now the oil soaked brake shoes look to be the same thickness.
Pedal height is adjusted by the clevis at the end of the brake rod.
