8n charging problems
farmermark
New User
. so my late model 1950 ford 8n wont charge. as
the battery has been disconnected for a while i
tried polarizing it but can get any sparks between
the bat and the arm termials. now since it is out
in the snowi thought id do some poking around
before i go tearing into it out there. thanks
Mark
I'll assume it's 6v........
Charge the battery then check it per tip # 49.
While it's charging, clean all the battery connections; see tip # 41.
If you can't get it to charge w/ a good battery, new cables & clean terminals, post back. It might be time to run some tests on the v/r & generator.
75 Tips
" what i was gettin at is not sure where?how to test thes old 6 volt systems "
I must have missed that in your prior post.
Try the flow chart. Post back w/ results or more questions.
75 Tips
so after chargeing the battery. i was going to test it but after to 10 sewcond attempts at cranking the battery was completely dead. the bettery is 6 months old and has all water in it and test fine. maybe starter drawing excessive amps? this makes the testing very hard haveing to recharge evry time you try
" water in it and test fine."
How are you testing it? A voltmeter? Hydrometer? Load tester?
" maybe starter drawing excessive amps? "
Possible, but that would be the last thing I'd check.
Battery, cables & grounds need to be ruled out first.
See tips 41 & 49 at the link.
75 Tips
