Engine Drain Cock
This is on 48' 8N gas by the way.
I can confirm it's p/n 8115 & that it's 1/4". And the same p/n applies to the radiator drain cock as well. But, the MPC does not specify NPT.
But I'll bet you a beer it is.
75 Tips
Just a common radiator type drain cock that some one installed into the block drain plug hole
Yes , a 1/4" NPT draincock or pipe fitting / plug will screw into that hole .
Did you know pipe threads are tapered . If you clean up old threads with a tap it will set the fitting in deeper . If they were not tapered a plug would spin all of the way through and would never tighten up .
(quoted from post at 23:44:50 11/23/14) Yes , a 1/4" NPT draincock or pipe fitting / plug will screw into that hole .
Tapered 1:16 to be exact, or 3/4" per foot. Just in case it ever comes up on "Jeopardy".
In this case yes but not all pipe threads are tapered. :shock:
The pipe threads on a female swivel are a common example of straight pipe threads (NPSI) . They match external NPT pitch and diameter but do not interfere with the tapered threads on a male fitting. The length of thread engagement is shorter than on NPT female fittings and in the case of a swivel the seal is not made on the threads - it is made between the chamfered end of the male fitting and the seat in the bottom of the swivel.
Just in case it ever comes up on Jeopardy ;-)
TOH
