what model is this?
It's a rowcrop. could be a 701 from what the seller reports. sure ain't a 6xx.
it has a 2 piece front pedistal, menaing it is later or has been swapped. I see the ps ram on the right.
all 53 and up if they have hyds, have live hyds.
i can't see the shifter, so it is either removed, or it is an angled shifter like a 5spd and out of the picture. you will need to see the model id on the trans to see if it is a dual stage clutch. *6* is what you are looking for. *5* and *4* are non live.
I don't see a sos shifter or hump.. but you knever know what has been removed.
not superior. In reality if could be a franken tractor since lots of parts swap.
could be a 900 series engine and tin and a different swapepd replaced tranny, etc, etc.
untill we see the engine casting and the trans code.. we can't say much other than the obvious.
same for the bolster. could be late or swapped... only way to tell is look at casting numbers and sn's to see if it might be native or not.
Thank you...I tried calling no vm set up.. so I emailed him. Maybe I can get ahold of the guy and go look at it tonight and get some numbers off it. But now that you mention it I didn't even notice about there not being a shifter..makes me wonder if it is a pieced together tractor. Not so sure the loader is worth 1500 but I like to negotiate and im cheap!
Old man called me back. Going to go look at it tonight. Said 3rd gear pops out and that he thinks its got a bad rod said he pulled the starter and can only turn it a little ways and it won't go any further. Said he's owned it for 35 years. Ran last summer...sounds like a pia..but will post back later
Do I see a remote hydraulic valve under the seat?
Nice option if it is. I don't see the remotes on the back.
Fenders look x01, but they are easily changeable too.
I can't tell if there's a fuel gauge and idiot lights in the dash?
Bad tires, rear axle seal leaking, wrong draw bar, needs
an overhaul and transmission work. Tough call.
At least he's not asking $3k for it in that shape.
(quoted from post at 02:50:36 11/21/14) Do I see a remote hydraulic valve under the seat?
We didn't make it over to look at it tonight had to do overnight care. Probably get over there this weekend and look at it in the daylight. I agree its needing lots of work but if it can be gotten for under a grand probably will be ok. Got a set of tires for it.
Shifter missing,armored tail lights mounted on the fenders,home made upper 3 point linkage,and the motor's locked up.Good Luck.
it's either a 700 or 900 series. They did have power steering. The PS is well known for leaking. Most of them around here have had the PS removed.
it looks to have the wrong drawbar.
