Reading that a single wire 10si alternator for a
9n will not start charging till it gets to around
1800-2000 rpm raises a question.
Does the 1800-2000 rpm refer to the engine or the
alternator?
The alternator pulley on the tractor I am working
on is around 1 5/8" diameter at the center of the
"V".
Can I calculate the engine/alternators pulley's
rpm's to determine the alternators true rpm?
I would rather run a single wire setup if it is
going to charge at normal engine operating rpm's.
I had bought a 197 lamped indicator light but it
uses the mounting bolt for the ground so it won't
really work the way I had intended.
Simple is better here I think.
alternator?
"V".
