I read the post on crack in engine block.
I had my 9N sandblasted and when I got it back home looked all around it and discovered a crack about 4 incnhed long at the bottom right hand side.I think I have 3 things that I might could do: 1. Weld the crack. 2. Use Epoxy base glue or J.B.Weld. 3. Try to find a used trainsmission case.
2 and 3 may need to remove the gears to apply the Epoxy glue or J.B.Weld. Would appreciate your thoughts on this matter.
