I have a 8N, as I was plowing it started to smoke. I shut it off and checked the engine. I found that I had a bad manifold gasket. It was dripping oil around the manifold. I replaced the gasket and started the tractor. It still smoked. Checking further
I found that the rear cylinder is pushing oil out into the manifold causing it to burn. Do I need to replace the rings?
Oil pressure is good when running. Spark plugs are clean.
