Don in Cal
Warning to new Stihl Owners..don"t leave the Stihl Dealer without having an authorized qualified Tech verify the mixture is correctely set..i.e. "leaned out" I purchased a MS 660 (7bph) saw last June ($1200.00, not cheap!) , it became progressivly hard to start and finally failed completely with less than 30 hours total run time. Returned the saw to the dealer who ended up rebuilding the saw under warrenty ($900.00) at no cost to me. The saw burned up becaused it was running too "lean" a mixture...came that way from the factory, the dealer apparently just assembled the saw and when it started considered it good to go when I purchased it. Cause of the problem was a bad Carb that could not be adjusted rich" enough to keep the saw from self distruction. Am happy that Stihl honored the warrenty and the Dealer did "good" by me!..but the lesson learned is that I should have insisted the dealer verify the saw was correctly adjusted/assembled and they should have not assumed the carb came correctly adjusted from the factory,so much for Quality Control! don"t repeat my mistake when buying such an expensive saw regardless of the manufacturer.
