1948 8N Governor Oil Leak
Hiney
I have tried searching the archives for this information, as I believe that I have read it before, but I wasn't able to locate the information that I am looking for. My governor seems to be leaking a far amount of oil from the governor arm shaft to governor body location. I am looking for feedback from anyone who has had this issue in the past and has successfully remedied the problem. I am looking for information such as the parts that were required and the methods to complete the repair.
Thanks,
Hiney
Here is a parts list to start
That is a pretty common leak on an 8n. I think you
need a new shaft, seal and a bushing. If the shaft
can wiggle up and down in the housing. it will
leak.
Thanks for the parts list and info on parts that are needed. Does anyone know where I can buy these parts that I need to fix the problem? The last time that I looked I couldn't find them at the normal places, nnalert's, here...or maybe I wasn't looking in the correct place. Any further help would be appreciated.
