Having a problem with my carb. It is a TSX-33 on a 9N. The carb was rebuilt and I'm now trying it out. I'm getting excess gas in the chamber with the venturi and choke plate and it's coming out the 'weep' hole - I got a little when I ran it a week ago; now I collected what I estimate is about 3 ounces of gas that dripped out this time. There was so much that when I took the carb off after letting it finish dripping, the inside of the air tube was wet and so was the choke plate. The bowl had gas in it as expected. I believe the needle valve and seat are ok since they are brand new parts. New gaskets, seals - your standard carb rebuild. The main jet, float, etc. are adjusted as per the book. The tractor is running OK also. The first 2 times I ran it recently (10-30 minutes each) had no problems, the third time I had a little dripping but nothing like this last time - and I had only run the tractor 5 minutes. I understand maybe a few drops here and there - but ounces? I also shut off the gas at the tank when not in use. Thoughts?
thanks in advance....
