restoration first start!
Well, it has been a good day. I have been pushing to get the 45'
2N far enough to fire it up, and today with my sons help we
made it happen. Mounted the radiator and hoses temporarily,
raidiator still needs work, and ran new plug wires, gapped new
plugs, rechecked point gap, and made a temporary fuel
container. Primed oil pump, and rolled it over until I got oil
pressure ( in 6V no less) and pulled the choke and turned the
key on. About 6 revolutions and it came to life.
Ran about 10 minutes checking everything over, good oil
pressure, about 40 warm (not hot) and about 20 idle. Running
10w30 for first oil, then changing to 15w40.
No leaks and runs smooth.
Rear end is up on stands and even put the new Sherman step
up in gear. Everything works as it should.
Good news and I wanted to pass it along to all on the board that
has helped over the last year.
Corey
