Lisa K
Figured I better ask before I act 3 pt lift won't drop. Dropped the fluid as it had water in it. Right side cover off valve moves freely with the control arm. Thinking next step is to drop the pump?
if this is an 8n, and the lil lever is moving and the 3pt is hyd up.. not just rusted. then it's haveing an exhaust problem.
pull the test port plug to exhaust the oil so you don't get a bath when pulling pump. ( 10-oz bath anyway.)
Yes sorry 48 8n. OK. Good time to get the pipes off they had in the test port for a loader. Thank you
As a rule of thumb for an 8N, it's probably a sticky exhaust valve. Remove the inspection plate w/ the dipstick, reach in & push the control rod to the rear. If the lift drops, you found the problem.
This is a classic symptom of a dirty pump.
Have you ever cleaned out the pump sump & changed the fluid? Check out tips 3 & 4 below.
There are two ways to clean the pump; the “quick clean” that gets a lot of the sludge out of it, & the right way that gets all of it, including the hard packed crud in the pump base.
For the quick clean, after you get the old fluid drained out (overnight is best) remove both inspection plates & start pulling the sludge in the pump base out by hand. Then, get a couple of gallons of kerosene or diesel fuel & pour it into the pump base. Catch it in a bucket & reuse it. (Some folks use a hand garden sprayer.) Flush the pump base out 5 or 6 times. Do not start the engine to run the kerosene through the pump; kerosene and diesel fuel do not have sufficient lubrication properties for a 60 year old hydraulic pump designed to be immersed in 90w gear oil. Some folks say it’s ok to start the engine, engage the pump for a minute or two, then turn the engine off. Your call on that one.
This 'quick-clean' is not as effective as dropping the pump & doing a full job. But if the choice is between doing nothing & the quick clean, spray it out. It worked for me for 3 years on my 1951 N. If you have the time, drop the pump; that is the right way to do it. I’ve done it both ways & don’t plan on doing the quick clean again. That’s because dropping the pump is not a big deal. If you have hard packed crud in the pump base, you are wasting your time w/ the "quick clean".
With all of the fluid drained out, block the front wheels & get the rear wheels up at least a foot. (you'll see why soon enough) Remove the 4 bolts holding the PTO shaft in & pull it to the rear & out of the tractor. Loosen all of the bolts. Remove all but 2 corner bolts. Then, carefully remove them. If you are lucky, the pump will drop free (and dump a pint or so of hydraulic fluid down your sleeves). If not, wrestle it free. The pump has 'ears' that fit into the housing; wiggle it a bit & it will drop free. If you have the rear tires a foot or more off of the ground, you will have enough arm room to hold the pump & lower it at the same time. Put it on your work bench & remove the safety valve (p/n 638) and the control arm lever (p/n 643) which will allow you to remove the intake & exhaust valves (p/n’s 640 & 698) Drop all of it in a bucket of diesel (or mineral spirits) or your parts washer & let it soak overnight. Once it has a good soaking, get it on the bench & start blowing it out w/ compressed air. Run cleaning fluid into the hydraulic discharge near the test port & make sure you get a good flow out the small hole in the side of the pump were the control valve fits. I don't see much need to pull it down any further just to clean it. But, I always replace the safety valve (p/n 638, about $25) Reinstalling the pump is harder than pulling it out because you have a gasket to worry about. (no sealer on the gasket) And, you will probably need a helper to guide the control rod into the pump rocker shaft unless you’ve done this 6 or 7 times before!
While you have the PTO shaft out, it would be a good time to replace the seal on it. It's got two spring clamps around it. Take your needle nose pliers & remove the one in the front. Then, hang the shaft & bearing housing in your vice & tap the butt end of the shaft; the bearing cap will come off (and the shaft will land on your foot). Then, remove the other spring clip from the other side of the bearing. At this point, remember that you never bought a seal driver & go get a big socket & drive the seal out. If you have the new style seal, the white side goes out. (open side to the oil) Put some grease on it.
Contrary to conventional wisdom, not a lot of water gets in the oil from the shifter boot. Of course, if it's bad, replace it, but you get water from the draft control spring & the dipstick. But, most water is just a byproduct of the heating/cooling cycle of the oil.
You’ll need a pump gasket, safety valve, inspection plate gasket(s), PTO seal, PTO gasket, gasket sealer & 5 gallons of fluid to do all of the above.
75 Tips
Ok..drained fluid, pulled PTO shaft, broke loose the pump bolts and was going to take off the pipes that are connected to the test port. Opened the valve on the pipe and the lift dropped, fluid shooting out the end of the hose that was on the pipe. So if I put the correct plug in the test port will it theoretically operate normal. May as well drop the pump and clean the sludge whilst I'm this far.
" So if I put the correct plug in the test port will it theoretically operate normal. "
Yep.
But be very careful w/ that port. It's aluminum & will strip easily.
The pump port is threaded 1/2-20 straight thread. You can buy a straight thread port fitting or you can make one from a 1/2-20 bolt.
Or get a SAE test port adapter fitting from The Old Hokie. Which is what I did.
75 Tips
I dropped the pump and replaced the parts Bruce suggested, and was glad I did. The sludge build-up in there is nasty and needs to be cleaned out. Mine did as yours does and it was the exhaust valve sticking. If you don't have a helper at the time you may want to use a floor jack to gently raise and hold the pump in position while you start the bolts.
