hard to start
dwbelcher
I have a 1950 8n that will start if I have a battery charger hooked to the battery while I am starting the tractor. It will not start without the charger hooked up to the battery. The battery must be to weak to start the tractor. How do I check the battery without taking the thing out and taking it to autozone.
Have you checked it with a meter-should read 12.5 or so volts-but could read this and still have a weak cell. Taking it out and getting it tested is the thing to do unless you have a load tester..
" How do I check the battery without taking the thing out and taking it to autozone."
See tip # 49 at the link.
6v or 12v?
If it's 12v, the AZ can load test it for you.
Good luck on getting a 6v load tested these days.
75 Tips
That tractor came new as a 6 volt. If the battery is more then a couple years old trade it in on a new one and save yourself a lot extra trouble.
" If the battery is more then a couple years old trade it in "
You can't be serious.
I get at least 6 & sometimes 8 years out of a quality (Deka) 6v battery.
Just keep them charged. Run them monthly or use a float charger.
75 Tips
a laod tester will tell you...
if it is charged and battery voltage drops heavily when you try to start, then you know it has a bad cell.
a 12v battery should be 12.6v or so charged, and not drop past 9-10 starting.
a 6v should be 6.3 charged, and not untder 4.5 starting. preferably 5.
