Installing a new axle pin this morning (pic)
Royse
Just sharing a pic of what it looks like.
You can't see the cribbing under the tractor, but it's there.
I use the floor jack to help me line up the pin with the axle
setting across two jack stands when working alone.
And Lawson......use a little anti seize......you may have to
replace that bushing again in about 60 years......just can't be
too careful......LOL
November first is fine Ed.
If you have room to throw that axle in that would be great!
This is that "ugly 8N" I brought home the other day.
My "good" 8N may still need it in the future! LOL
You got it.....and its got the hubs as well....I ain't taking them apart....you're getting them if you want them or not!!!...lol.....still will have two lying around!!
Your housing looks a lot better than mine. Do they all look that good or is mine just screwed up? (Can't link sorry)
http://s742.photobucket.com/user/crackface666/library/Tractor
I'm not sure which part of the housing you are referring to,
but yours has been modified to hold the front "stinger" pump
for a loader. It's a common modification. Does make it harder
to get to the pin and the loader makes it more likely to need one!
Here's a link: SlideShow
