Battery cable ? 6v system
BenderBrau
New User
This isnt a question which cable goes to which battery terminal. Ive had the tractor apart for way to long now while trying to get my distributor worked on(which has been a huge PITA). Anyway i disconnected the negative battery cable from wherever it hooks up and cant for the life of me remember where it goes. Any one have the answer? I left a 3" bolt and washer in the cable and do not remember if I need it for the cable or I did that so I wouldn't lose the bolt. :? If you made it to the end of this post thank you, any help is appreciated.
Thanks for the reply. It does go to solenoid, just found a picture on here of it. No idea why I put the bolt through it, guess ill find out when something falls off.
Here's where both cables go.
75 Tips
