(quoted from post at 08:56:43 10/20/14)
(quoted from post at 02:49:22 10/20/14) My latest project tractor 52 8N s/m pos/gd 6V has only 2 more steps to the finish line. I replaced everything in the electrical sys except the starter. It is no secret I am electrically challenged but I decided to tackle a 101 8N as I think the N is very basic Inter-comb-eng and a simple basic rewire job to cut my teeth on. I used Archives, JMOR diagrams and Bruce 75 tips along the way. Here is the short of it. Ran a new wiring harness and got it running but I still fail to understand the amp meter part. It is the 30 amp 2 post no loop gauge, harness is no loop.Black plastic shield on Yellow battery wire from solenoid and a plain Yellow from Bat on regulator. I polarized the sys. When starting the amp meter it moves as motor cranks but stays close to 0 on start up, no matter the rpms and no drop with lights on. A picture of how the back of amp meter connection goes would help. I may have it right and not know it. I have another 52 that it pegs the amp meter + when I give it rpms. It is the original face type with the loop. It has a loader and the wires are dirt covered and hard to see due to the loader so I cant use it as a cheater. Thanks
n this photo, the wire coming out of harness and passing through the ammeter loop (from center of tractor toward outside, i.e., toward the right in photo or toward the left as viewed from driver's seat) has a clear sheath on it & your a black sheath. This should connect to the positive terminal of the ammeter, as it is the battery connection (yes, I know that it is the battery's negative post). The negative ammeter post should have a wire connecting it to the 3rd terminal of the resistor block if your tractor had a front mount distributor (as shown here), but since you have a side mount distributor & no resistor block & instead, have a two terminal block, then this ammeter negative post will go to the bottom terminal of your 2-terminal block. The other two wires on that bottom terminal will be one going to ignition switch (small black wire in photo) and the un-sheathed heavy yellow wire coming from the voltage regulator BATT terminal. The terminal block top terminal will have the small wire from the ignition switch and the wire going to the ignition coil's negative terminal. You did not say where your light get power, but it should be from the bottom terminal of the 2-terminal block. If lights get power from the battery (solenoid post, battery side (+) of ammeter, then lighting current will NOT register on your ammeter. As for ign current registering on ammeter, it will be very small. Approximately 4 amperes with key on, engine stopped in such position as to have the points closed. When running the average current drain of the ignition will be approximately 1/3 of that 4 amps or about 1.3 amperes & nearly impossible to discern on a 30amp meter scale. This 1/3 is due to combination of dwell & the L/R exponential charging current of the ignition coil.
