On no, not another oil question:
For Hokie: you seem to be up on the oil questions.
I used 10w40 oil plus 1qt of Lucas oil stabilizer in
my old tractor, but when plowing, about the hardest
work it ever does,
When at idle and normal operating temperature, the
oil pressure gauge would be on the low end.
I changed to 15w40 shell rotella oil, the oil
pressure appears to hold a higher pressure.
Is that in my head or is there some reason for the
higher pressure. I understand that oil has a good
additive package.
Should I still run a qt of Lucas oil stabilizer in
the oil?
Thanks for any input.
I change the oil each spring to drain out dirt and
condensation.
work it ever does,
additive package.
the oil?
condensation.
