I need some help identifying a part on a 9N ford. At least I believe it is a 9N. The governor self destructed, and poked a hole about the size of a pea in the bottom of the casting. So I guess I need a new governor. I did some research and read through the various forums on this subject, and found a close replacement part, but mine is a little different. All the governors i found online have an oil line connecting into the back of it. Mine doesn't. Also, everyone talks about making sure the short bolt is put into the top of the governor, but mine has a stud with a nut on it. Other than that, the ones I have found online look like they would work. I would just like someone’s opinion on this that knows what they are talking about. Is the oil line absolutely necessary? Since mine doesn't have that oil line, or even a fitting on the governor, could I use one of the governors I found online and plug that fitting off? I hate to buy one and find it will not work, or worse yet, cause further problems because I don’t have an oil line connected to it.
I'm pretty sure this tractor is a 9N.
