8N Ignition Problems with Side Mount Distributor
Lately, my Ford 8N with the side mount distributor has been losing its spark. I replaced the points and condenser. It ran fine for two days and then lost its spark. The point setting was set to .025. I remove the wires to the condenser and to the distributor and then re-connect them. It starts right up but then quits in less than five minutes. What could be the problem?
(quoted from post at 16:41:01 10/15/14) Lately, my Ford 8N with the side mount distributor has been losing its spark. I replaced the points and condenser. It ran fine for two days and then lost its spark. The point setting was set to .025. I remove the wires to the condenser and to the distributor and then re-connect them. It starts right up but then quits in less than five minutes. What could be the problem?
heck your feed-thru insulator & copper strip
