Hi, I am new to the forum & would like a little help b4 I go nuts trouble shooting this 2N. The following is what I have completed thus far.
1. It was converted to a 12V system.
2. New points,rotor,dist cap,capacator,plug wires,12V magnito,resistor (as per 12 V spec)
3. Dry compression test was 60 on all 4 cylinders.
It starts & runs great when I bypass the resistor. It will not start with the resister in place. It will back fire & hit on an occasional cylinder. Almost seems like a timeing issue. I then jump the resistor & all is fine. Could it possibly be a bad new magnito? Help, while I still have a little hair left. Thanks!!
