8N Lift Repair (first one for me)
whopist
Purchased my first N Tractor over 5 years ago and now it’s time to open the “lift top cover” on an 8N. Never repaired one before but knew the day would come, so I collected all the tech data and pictures that might help for those 5 years.
The 8N lift had these symptoms:
- The lift was very slow to rise and would not rise on accusation.
- It was fast to come down [and] if the PTO was stopped the lift would leak down in less than one minute.
- The lift would sometimes only rise half way and not go any higher.
- The touch control lever did not move smoothly through its travel range. It actually felt like it was binding; although, it did travel through it entire range.
- The small Position Control Lever was stuck in the up position (position control). But the lift operated like it was in draft control.
- With the round side cover removed and the lift holding up a shedder there was a steady stream of fluid coming out of the ram cylinder.
Removed the lift cover and found this:
- The lift cylinder piston was NAA, the “O” ring was shot and the back-up washer was gone.
- The ram cylinder needed honing.
- The 8N540A2 position control link was bent.
- The 8N504 hydraulic control lever was bent.
- The cam following pin had some wear.
- The spring washer (lever to shaft) 9N522A was broken into two pieces.
- Washer 351502-S (hydraulic lift control shaft to friction plate) was missing causing lever to shaft to not have any tension.
Action taken for repairs:
- Replaced piston “O” ring and back-up washer.
- Honed the ram cylinder
- Straightened the position control link.
- Straightened the hydraulic control rod.
- Replaced the can following pin.
- Replaced the spring washer.
- Added washer 351502-S
Reassembly and adjustment remarks:
All research indicated this might be very trying for my first time repair, but not so. Two documents showed me the way:
- FO-4 Ford Shop Manual
- Procedure For Adjusting Ford Tractor Hydraulic Mechanism from the Service Equipment For Ford Tractor Manual (see links below)
After straightening or replacing all bad parts, I reassembled the lift cover. I did not use any alignment fixtures, but found the pictures of them in use, along with a carpenter square and straight edge scale were all I needed to make the final adjustments.
I did clean and flush the pump and case, also put in new fluid.
Position and Draft mode both work great!
Cowboy, if you are asking about the "Procedure For Adjusting Ford Tractor Hydraulic Mechanism", maybe we can ask if it can be added to the Library here on YT.
Here is another post on lift repair and linkage adjustment. Post 33 & 34 are noteworthy!
<a href="Lift trouble shooting thread" target="_blank">Link: http://www.external_link.com/showthread.php?t=685353&page=2</a>
