1948 8N, front mount distributor.
I have attempted to see if I have spark to the
plugs by pulling one of the wires, inserting a
plug in it and grounding it as I turn the engine
over...no spark visible. Someone here suggested a
"real" spark tester was the only way to go. So, I
purchase one that has an adjustable gap. The
instructions say to adjust the gap the same as
that which is normal for the plugs in the engine. Is that the
correct procedure for use with my 6 volt system
(it came from an auto parts store so its for 12
volts, I would assume), or should the gap on the
device be set to something else?
