The linkage and carb are working fine. When you back off the throttle you hear it make a zzzzzzzzz sound like a gear is stripped. The linkage all goes into a little box which is where the zzzzzz sound is coning from. It looks like there's probably oil in the box, so I wanted to hear your thoughts before tearing into it. Anyone experienced this? Any reason I can't take it apart to see what happened?
Also, if I manually twist the throttle from the side of the carb, I can get more rpm's out of it. In other words it will rev higher by hand than through the throttle bar by the staearing wheel. Is this normal? Should I adjust to get max throttle out of it?
Thanks
Thanks
