Working on my 2N and I am trying to figure out what things are. I am adding a key switch to keep my kids from starting the tractor since it was wired with a hot start button on the dash. I have a push pull switch that seems to do everything. Can anyone identify this switch, pn or name or something. I am thinking I would like to replace it.
Next, I am trying to figure out why, if I am right, there is 2 resistors wired in series to the coil?
Next, can I put a water temp gauge in the side of the block where I pulled a plug and drained the water? Will it give me an accurate reading?
The oil fill tube is loose and leaky. Is there a simple fix for this, other than buying a replacement tube?
