so I have the dearborn front plow on my 8n. for anyone who doesnt know, the plow uses steel cables that run under the tractor to front axle brackets to lift the plow.
originally, the cables are designed to have a threaded rod end on the front axle, so you can take all of the slack out with a nut. obviously my cables are not original, as thats missing. for last year, I simply wrapped the cables around the axle and used cable clamps. While this let me get the cables close, it wasnt perfect.
where can I buy cable with theses ends on it? or can I buy the ends and have it pressed onto my cables? Would like to get this figured out before winter hits!
