Went out tonight to see what I could figure out. Of course I tried to start it and no go. It fired once or twice and I once again wore the battery down a bit. Pulled plug out bottom of bowl, great gas flow. Pulled #3 spark plug and it was dry but seemed as Once again it was flooded, gas dripping out throttle shaft. When I loosened the hose clamps on the carb throat gas did come out after i got the hose unstuck from it. So pulled the carb, needle looks brand new, which it practically is, made sure all passages were open with carb cleaner and air. Checked the float setting, I suppose it was maybe 1/8" too high. Dunked the float and it floated and didn't fill with liquid. Readjusted the float stuck it back together. Bowl filled got it to fire 2 times and no start. So I checked spark. Several revolutions only produced one blue spark and it seemed as it would spark when releasing the starter button. Battery voltage was 12.1 I threw the trickle charger on it and had to get the kid home. So im hoping after getting the battery charged back up it will start.
