PAINT THE UNDERSIDE OF A 8N
HIVEY
THIS MIGHT SOUND STUPID,BUT HOW DO YOU PAINT THE UNDERSIDE OF A 8N TRACTOR.IT IS ON BLOCKS OUT SIDE.DO I NEED TO CRAW UNDER THE TRACTOR.
ANY SUGGESTIONS.
This may sound stupid too, but just get enough on the top & it will run down there. Yes, you have to get under it.
paint brush works pretty good underneath.
cement blocks? take a good jack stand with you and set it next to you every place you lay down.
hey, at least you thought of the bottom.
a large percentage of 'fully restored' tractors I buy don't have a bit of new paint on the belly, or the backs/bottom of the radius arm, axles, etc LOL
pressur epot gun, gravity feed gun or paint brush..
syphon won't get it for ya unless you got her jacked up real high.
Your HVLP gun should work just fine for getting under the tractor. A brush will also work but will take more time and use more paint.
Colin
read this last night, this what I use for painting under most things I also use it for hard to reach areas. this is one on harbor freight and tools, about 45-50 dollars.
didn't up load picture
