51 side mount, 12v EI conversion. Ever since the rebuild it was simple to start. Key on, 1/4 throttle, pull choke out, hit starter button and she'd start right up. Rebuilt carb, new fuel sediment bowl and all new screens at time of rebuild, gas tank is clean less than 15 hrs ago. Fuel flows great when I can get it started. All of a sudden I cant get it started easily if at all. My magic starting procedure no longer works. Sunday I finally got it started after I flooded it trying to start it and running the battery down. Shut it off for a bit and could not get it to restart, it flooded. Am I needing to take the carb apart again. I run premium gas in it and always run the carb empty or close to when I wont get to use it again for a week. has good spark. And yes I put gas in the tank. Sometimes it will fire once and then sometimes not. Needless to say im slightly irritated with it. I tapped on the bowl thinking maybe the float was stuck and no luck. TIA
