Lower draw bar arm hitch pin main bracket removal. How to...
Iven
New User
I am trying to get the plate off of the draw bar arm front bracket
to replace gasket. Any help? Thanks. Ford 9n.
Are you talking about the lower 3PT lift arm pin where it attaches
to the axle trumpet or do you have an aftermarket drawbar setup?
If you are talking about the attachment of the lower lift arm to the rear end of the tractor, there is a castellated nut inside the diffy housing. Need to remove the axle and the axle house to get to it. If you remove the left axle and housing you can then lift out the differential so that you can do the right side also.
