BlackThumbHomesteader
This situation appears to be the norm from what I've read.
The 6v system in my tractor died this spring(coil bad, wiring frayed and corroded, battery not holding a charge) so I went with a 12v conversion. I have been reading a lot of forum posts on my trusty 2N and wired up an external can coil replacing the location of the box coil with non-conductive plastic.
My wiring scheme is thus;
Ammeter-
Terminal #1 to resistor block #3
Terminal #2 to starter toggle #1
Starter toggle-
Terminal #2 to resistor block #2
Coil-
Negative to resistor block #1
Negative to condensor
Positive to points
Alternator-
Terminal #1(single wire) to resistor block #3
I have tested each wire for continuity. The battery is new. The points are not burned. The distributor has been static timed properly. I have looked at dozens of wiring schemes and tried many of them. The wiring was done with and without the ceramic resistor in place. I do not have a voltage regulator. The starter turns fine. I get no spark with any wiring scheme. I also think that the condensor is on the wrong pole.
After justifiable admonishing me for my shoddy "upgrade" can I get some assistance untangling my wiring issue?
Ammeter-
Starter toggle-
Coil-
Positive to points
Alternator-
