50 side mount 12v Loaded tires
Left rear started leaking air out of the valve stem. So far I've determined I have a two piece valve stem and there is a chance I can replace the outer portion and not go into the tire to replace the whole valve stem. It looks like I've also lost the washer and nut.
While confidence is not high to get it done due to the condition and corrosion, theoretically I should be able to grab the outer portion at the knurled part and twist out said outer portion and replace.
Any tips and confirmation would be appreciated.
