Tall T
Well . . . on the job learning. Hi Ho hi ho
Or put another way . . . what you were trying to tell me.
The steeper the bridge ramps are, the more torque demand is on the rears so the front end gets lighter . . . especially with a rear load. But I did lessen the angle of the left ramp as much as I could, without having to redo its nailing base to the log. I think that ramp was where I used one of my two 8" spikes with the others. The metal ramps are now held down with L iron bolts.
I think I'll hang an old 6 cyl crankshaft from the front bumper that's easy to unhook. Probably use old connecting rods to hang it from the rod journals with a long iron bar through the wrist pin end, the small end . . . hanging from a bar like my black weights, but on a solid rod. I'll have to see what the ID of the rods I have are with the pin bushing in or out. I've been saving them but I think my Chev rebuild will outlive me and won't ever need them. I'd still have 4 spares.
Ideally, the crankshaft and my black weights should both hang from the same bar. How much weight can those bumper brackets take . . . the way they are mouned?
That plasticote chrome on my headlight rim, would be greatly improved with a hardener. Even a plastic tarp leaves an impression on it and because of touch it looses its shine . . . but it stays stuck at least. I should have put a hard clear coat on top. If Plastikote could be bought non-spray could a hardener be found that would work?
